What amp circuit breaker for Precision Tig 185?
发表于 2021-8-31 22:12:45 | 显示全部楼层 |阅读模式
Hi,I'm a proud owner of a previously owned Precision Tig 185.I'm planning to use it in my home shop in California.  Can somebody please tell me the recommended size circuit breaker?  I plan to use it in the Single Phase mode.The manual show 35A/32A Effective and 70A/64A Maximum.I'm not sure if this means that I can wire it to a 35A circuit or 70A circuit breaker.Any help would be appreciated.Thanks,RodSan Francisco
Reply:The maximum is your inrush current that can trip a breaker, depending upon your actual maximum setting. The effective is the "running" current after start up demand has been satisfied when the arc is started.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:lugweld,Thanks for the explanation.I still need to know what size circuit breaker should I plan to install.Anybody?Rod
Reply:70ampEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Hi rodjava since provided the necessary circuit breaker info I'll provide some additional info to help.If you go to http://www.tig185.com/service/ the Lincoln folks can provide you with an owners manual and parts guide. The site can also provide you with additional guidance as to set up and operation. They also have a Precision TIG 185 forum to help you out.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Lugweld,70amps, Thank you.RodSan Francisco
Reply:Spector,Thank you for the link.  I have the same as a printed manual.  Unfortunately, there is now actual reference to what amp circuit breaker to wire too.  It assumes that I should know this, but didn't.RodSan Francisco
Reply:You could get by with a slightly smaller one as they recommend the super lag fuses and thermomagnetic breakers...possibly, but you dont have any guarantees it won't trip at that.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2026-1-2 10:31 , Processed in 0.214730 second(s), 18 queries .
