Klutch MTS 220A welder from Northern????
发表于 2021-8-31 22:12:43 | 显示全部楼层 |阅读模式
This looks like a pretty interesting machine. I understand Northern has a good reputation for standing behind what that sell. The welder is supposed to put out 220a for mig welding. It is very light at 30lbs. And comes with a spool gun. At $670, it seems like you are getting a lot for your money. I haven't been able to get much real life info on it. Does anyone have any feedback????Thanks,Petehttp://www.northerntool.com/shop/too...1881_200631881 Attached ImagesEverlast  i210 with 200a spool gunEverlast i140eLOTOS LTP5000D Non-Touch Pilot Arc "Things are never so bad that they can't get worse...."
Reply:My friend bought the klutch inverter 200 amp stick welder and he has run the snot out of it, it's still going. I bought the same welder because it has a lift tig function, I use it for tig welding. Northern told me they now repair all their welders in house. So far the 200 amp welder has worked well for me with a tig rig. Don't know how well it will do over the long haul.
Reply:Thanks for the  info.PeteEverlast  i210 with 200a spool gunEverlast i140eLOTOS LTP5000D Non-Touch Pilot Arc "Things are never so bad that they can't get worse...."
Reply:Originally Posted by kctgbMy friend bought the klutch inverter 200 amp stick welder and he has run the snot out of it, it's still going. I bought the same welder because it has a lift tig function, I use it for tig welding. Northern told me they now repair all their welders in house. So far the 200 amp welder has worked well for me with a tig rig. Don't know how well it will do over the long haul.
Reply:I was checking that setup out earlier today but I am torn.  At $699 plus another $100 for the Tig torch you can get the Tweco Fabricator 141i plus the Tig kit that supports GTAW for $50 bucks less.  Decisions decisions...
Reply:I think you would be better off with the Klutch unit. The Tweco Fabricator 141i is not all its cracked up to be IMHO.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Originally Posted by GCharronI was checking that setup out earlier today but I am torn.  At $699 plus another $100 for the Tig torch you can get the Tweco Fabricator 141i plus the Tig kit that supports GTAW for $50 bucks less.  Decisions decisions...
Reply:Originally Posted by fpsWell, you’re looking at two different machines. The fabricator does not have enough power to really do aluminum or thick steel. The klutch has the spool gun and enough power to spray transfer, which is basic must for aluminum. Also, unless you are doing rather special welding to need the tig, a mig setup works much better for the hobbyist. Of course a dc tig can’t do AL, either.FWIW, there’s a giant different between a hobbyist welder and even a professional small parts/repair welder, compared to the guy’s here that work on 2” thick steel dozer blades/buckets, a big excavator, or track hoe machines.Getting the right answer from this or any other forum takes you, “the questioner” to fully clarify “exactly” what your hopes and expectations are from the machine you're interested in.As a hobbyist, I’ve been though over 7 machines in the last few years zeroing in on what machine is the absolute best performing machine for my needs. Needless to say “one” machine just won’t do it!!
GMT+8, 2026-1-2 10:31 , Processed in 0.084194 second(s), 18 queries .
