Metric MIG Chart & Boots
发表于 2021-8-31 22:12:42 | 显示全部楼层 |阅读模式
Hi guys and girls,new member and absolute noob welder, all i have manage to do so far is burn my feet with splatter (yep im the guy that started barefoot, granted i was only playing on 50mmx50mm plate.). My welder does not have a chart in the door and i am having trouble finding a metric chart. Everything seems to be in imperial, but my welder is metric and i want to be lazy and not have to convert.  Can anyone point me in the right direction of a good image/doc i can print out and stick in the welder where one should bt? Also, back on the shoes.  I have some old hiking boots, the synthetic type not the heavy leather. would these offer much protection or do i really need to fork out and get some leather steel caps?  Happy to spend the money, but wont if i dont have to.These are what i have Thanks in advance.Last edited by TheRealTy; 03-13-2016 at 09:49 PM.
Reply:are you looking for metric amps or metric volts?sorry, couldn't resist.have a look at a european mig wire seller, they have charts online.for example:wire size  ---  steel  --  stainless  --  aluminium0.8 mm  --  60-200 A  --  50-140A  --  60-170A1.0 mm  --  80-300  --  80-190  --  90-210Ayou'll find better charts online, probably with wire speed rather than amps.
Reply:Originally Posted by kingneroare you looking for metric amps or metric volts?sorry, couldn't resist.have a look at a european mig wire seller, they have charts online.for example:wire size  ---  steel  --  stainless  --  aluminium0.8 mm  --  60-200 A  --  50-140A  --  60-170A1.0 mm  --  80-300  --  80-190  --  90-210Ayou'll find better charts online, probably with wire speed rather than amps.
Reply:Have y ou tried looking on their website.http://www.unimig.com.au/catalogue_p...tegory=1#.Then select setup manual you will find what you are looking for. They have a chart for wire speed and voltage there. Now that could not get any easier than that.Klutch 220si mig , stick, and dc tigHobart 140 AHP ALPHA 200X 2016Lotos LTP5000DSmith O/P
Reply:Originally Posted by tinker001Have y ou tried looking on their website.http://www.unimig.com.au/catalogue_p...tegory=1#.Then select setup manual you will find what you are looking for. They have a chart for wire speed and voltage there. Now that could not get any easier than that.
Reply:Originally Posted by TheRealTyAlso, back on the shoes.  I have some old hiking boots, the synthetic type not the heavy leather. would these offer much protection or do i really need to fork out and get some leather steel caps?  Happy to spend the money, but wont if i dont have to.These are what i have
Reply:Originally Posted by OkieDaveGet the leathers.  Synthetic + heat = bad.  The synthetics will melt, then fuse to your skin.
Reply:or get leather welding spats.Klutch 220si mig , stick, and dc tigHobart 140 AHP ALPHA 200X 2016Lotos LTP5000DSmith O/P
GMT+8, 2026-1-2 10:42 , Processed in 0.075105 second(s), 18 queries .
