Flux Core Welding Pot Metal
发表于 2021-8-31 22:12:41 | 显示全部楼层 |阅读模式
I know it's mostly zinc, but I was wondering if it were at all possible, and how strong the joint would be afterwards? I have a Tweco Fabricator 181i, so I can do TIG if I can get some argon, right now I can only do flux core or stick as I don't have any gas bottles even though my machine is multi-process. I don't know how to solder so that sort of rules it out as I don't want to practice on something I am trying to fix for someone. Any thoughts?It's a hook type of thing that you mount to your wall by the way, so the hook is a rod that's in the shape of a fishing hook, and the rod is around 3/16" diameter. The pot metal broke right on it, so I was going to try and tack it back together. Maybe some epoxy would be better.Tweco Fabricator 181i"Always remember to be unique. Just like everyone else."
Reply:I've seen this: http://muggyweld.com/alloy-1But it looks to be for low temp stuff like soldering.Tweco Fabricator 181i"Always remember to be unique. Just like everyone else."
Reply:Zinc can be soft soldered.
Reply:Use glueYeah, I know, but it'll be ok!Lincoln Square wave 255Miller Vintage mig30a spoolgunThermal Dynamics Pacmaster 100xl plasmaSmith mc torchEllis 1600 band saw
Reply:Originally Posted by welderjUse glue
Reply:TIG will vaporize zinc.TIG temperatures: 3000-6000 deg.C   http://hypertextbook.com/facts/2007/AnthonyHo.shtmlZinc boiling point: 907 deg.C http://education.jlab.org/itselemental/ele030.htmlHere's a zinc table top being soldered:http://vanhookandco.blogspot.com/201...eet-metal.htmlUsually people learn soldering before TIG welding.
Reply:Originally Posted by Denis GTIG will vaporize zinc.TIG temperatures: 3000-6000 deg.C   http://hypertextbook.com/facts/2007/AnthonyHo.shtmlZinc boiling point: 907 deg.C http://education.jlab.org/itselemental/ele030.htmlHere's a zinc table top being soldered:http://vanhookandco.blogspot.com/201...eet-metal.htmlUsually people learn soldering before TIG welding.
GMT+8, 2026-1-2 10:42 , Processed in 0.291078 second(s), 18 queries .
