Springs - looking for some idea's
发表于 2021-8-31 22:12:32 | 显示全部楼层 |阅读模式
I pick up a small bunch of these springs from work. Any thought's on projects I can incorporate them into. The couple that came to mind were a sprung stool, or animal rocker ride for the yutes."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:You could make a heck of a ram bar for the pickup. Prius's be flying everywhere.Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:New pogo-stick to the moon or the ISS?  Maybe we could resupply the ISS by using your springs instead of renting Russian rockets?I really have no idea what I am doing.Two Shop Cats (not Bobcats...real cats)Miller DialArc 250 AC/DCScratch-Start TIG SetupMIG 175Plasma CutterO/A
Reply:Weld an old steel tractor seat to the top, a plate and truck rim to the bottom and you have a springy-stool for the shop.
Reply:What did they come from ,with that machines surface looks like maybe out of a safety valve? Is that a green tag was it for nuclear use at one time? just had another of my seldom brilliant ideas,build them into each  bed post for more action!
Reply:Originally Posted by shortfuseWeld an old steel tractor seat to the top, a plate and truck rim to the bottom and you have a springy-stool for the shop.
Reply:Spring loaded mail box post.
Reply:Originally Posted by welderjNow that is an excelent idea!
Reply:Iv'e seen guys take springs and use them to tension cables and give them a spring action.  You will sometimes see a manufactured version on cables used for highway medians where teh spring absorbs the impactI was thinking they would be good for a gun target.  Weld a piece of AR plate on top.  Put a flag pole so when you hit them you should get the noise and see the flag waving.
Reply:Toss it in your forge and straighten it out. Should make excellent material for new forged tongs. Note quenching is probably a BAD idea..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:you could stack a bunch of them in the right sized diameter of pipe.    Then put a golf ball, or harpoon on top.    Then compress them.   Then need to figure out some way to hold and release the load.
Reply:Originally Posted by gxbxcThose spring are only 6" high it will be a really low stool . But on a monday night at Sam's place no one would get hurt falling of the bar stool!
Reply:Cool find I'm sure you will find something to do with em!!!
Reply:They might be equipment isolators without the top and bottom mounting plates that have a recess that they fit into. They look pretty ridged.You could cut them into rings and make the wife or girlfriend a necklace, use the rings for eyes on a shovel for yard art,  pawns for a BIG chess set, maybe a yard art heavy duty sunflower flower that you need a crane to set  or arms or legs for something.
Reply:A big retracting ball point pen!12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:Originally Posted by 123weldyou could stack a bunch of them in the right sized diameter of pipe.    Then put a golf ball, or harpoon on top.    Then compress them.   Then need to figure out some way to hold and release the load.
Reply:Originally Posted by Austin BennettYou could make a heck of a ram bar for the pickup. Prius's be flying everywhere.
Reply:I would use a few of those to stabilize a part vibrator for deburring and such.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Valve float would be a thing of the past with those things........zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by BistineauHow many of these springs do you have/can get, stickman?
Reply:I was going to suggest you could put four of them under the heel of each shoe, just like the shoes I see the Kool Kidz wearing these days.
Reply:Two yutes...cracked me up...still laughing...good one samm
Reply:Ok, I ended up with twelve of these springs. Still haven't thought of anything definite to do with them yet."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
GMT+8, 2026-1-2 13:43 , Processed in 0.111491 second(s), 18 queries .
