finger control torches
发表于 2021-8-31 22:12:31 | 显示全部楼层 |阅读模式
was thinking bout getting one for my dynasty 200 dx. i like the press button idea, buit cant find any. all i see are "roll" controls on torches. any insight, or reviews? thanks, Joe
Reply:Are you looking for an arc start swith? Sorry if I do not understand you question Best RegardsMauricio
Reply:I have one from weldcraft that I love. Switch on/off, roll adjustment, air cooledDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Originally Posted by turkI have one from weldcraft that I love. Switch on/off, roll adjustment, air cooled
Reply:I had the Miller east/west wheel hand controller.  Couldn't stand it. Too hard to adjust on the fly w Aluminum. Joe, an on off switch, even with the auto slope settings on the machine, is not gonna give you the control you need on Aluminum.  Even after a programmed hot start, your gonna need to control the amperage as the piece heats and especially near the end of the piece.  Maybe a pro will chime in about the validity of my statement, but it's what I've found to be true.  You can speed up as the matrial gets hotter, but it's not the same control as backing off the pedal.  And this needs to be done faster than my hand switch could.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Originally Posted by Drf255I had the Miller east/west wheel hand controller.  Couldn't stand it. Too hard to adjust on the fly w Aluminum. Joe, an on off switch, even with the auto slope settings on the machine, is not gonna give you the control you need on Aluminum.  Even after a programmed hot start, your gonna need to control the amperage as the piece heats and especially near the end of the piece.  Maybe a pro will chime in about the validity of my statement, but it's what I've found to be true.  You can speed up as the matrial gets hotter, but it's not the same control as backing off the pedal.  And this needs to be done faster than my hand switch could.
Reply:Pedal is the better choice for precision, but sometimes it is not an option , I use both in their placeshere is the aircooled torch numberWELDCRAFT LS1725R 25' TIG TORCH W/14 PIN REMOTE MILLERLast edited by turk; 10-14-2012 at 01:29 PM.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:If you are only getting one then the pedal hands down.  The finger control is good for when u are not able to sit at a table and weld.. Out of position like under a trailer etc.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Why are you selling the Dynasty DX already??Man, I thought I was fickle about machines.  I'm on my 6th TIG/Stick in a year, but now I'm done.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
GMT+8, 2026-1-2 13:48 , Processed in 0.120170 second(s), 18 queries .
