Welding rod
发表于 2021-8-31 22:12:24 | 显示全部楼层 |阅读模式
I have a 10lb box of Brutus-A high strength 125,000lb psi rod that I got as part of a purchase of a used Miller Thunderbolt.Can anyone give me an idea on what it is worth?  ThanksGreg
Reply:Rockmount AlloyBrutus? Alot i had some twenty years ago it was about 50 $/lb08 Lincoln Ranger 250 w/Remote94 Lincoln G9 Pro68 SA-200 Red FaceLincoln 250 Idealarc w/remoteMiller 250 Syncrowave
Reply:Put it on eBay with a high reserve (or as much as you think it is worth).The true worth of the rod is what someone is willing to pay for it.
Reply:thanks!  I may try the eBay route or consider offers here.  Greg
Reply:If you ever need it you may regret selling it. I'd weld some samples and bend/break 'em to test...
GMT+8, 2026-1-2 13:49 , Processed in 0.178280 second(s), 18 queries .
