Miller Syncrowave 300 Current Sensor 004 590 part WANTED
发表于 2021-8-31 15:01:53 | 显示全部楼层 |阅读模式
Hi ForumI have damaged the old Current Sensor wires.. I stupidly removed the Board off with the Hall sensor with everything still in place.This pulled all 4 wires out of the sensor. This part is now listed as obsolete..Does anyone have a second hand unit or know how to get NOS. (New Old Stock)RegardsPeter
Reply:Looks like these guys have one, but it is pricey https://weldingmart.com/miller-elect...-sensor-004590Miller Multimatic 255
Reply:There are also circuit board repair companies that can fix that for you. Not sure how much that would cost.  https://www.qie.com/MILLER/004590Last edited by Louie1961; 03-03-2021 at 07:26 AM.Miller Multimatic 255
Reply:Im the same problem  , II Need to know how Work the sensor for make one
Reply:Hi did you get the sensor 004 590 for your miller sw 300?
GMT+8, 2025-12-18 18:23 , Processed in 0.090167 second(s), 18 queries .
