invertec error codes
发表于 2021-8-31 22:12:20 | 显示全部楼层 |阅读模式
I was attempting to run my Invertec 205-t on a (cheapo) generator today- it shut down with an error code. I"m pretty sure that the code was E-13- -- does anyone know where to get a complete list of the codes? The manual only has a few, and that's not one of them.Thanks!Andy G.
Reply:I have the 205 also and it sounds like it doesn't like the dirty line voltage from the generator. Does it throw a code when you plug it in normally?
Reply:I called Lincoln and these are the codes you need.... Attached Images
Reply:Thanks for the chart, gocirino!If that is the code it threw (going from memory here), any idea how to reset the front panel? It looks like there's something written below the error code chart, but I can't figure out how to scroll down in the image you sent.I'm assuming that it's just a warning about the poor power supply, but thought it good to double check.Andy GEdit: I think it was probably E12, and I misremembered it....would make more sense, since the machine welded for a half minute after the first time the code came up..Last edited by ElementFe; 12-02-2010 at 01:00 PM.
GMT+8, 2026-1-2 12:07 , Processed in 0.102249 second(s), 18 queries .
