do I max out on rod amperage to get better penetration?
发表于 2021-8-31 22:12:18 | 显示全部楼层 |阅读模式
Hello all, I have a small 120v arc welder. If I wish to weld thick material, do I just use the largest electrode that the machine can handle and max out on the amperage or do multiple beads? Thanks
Reply:Originally Posted by bikercatHello all, I have a small 120v arc welder. If I wish to weld thick material, do I just use the largest electrode that the machine can handle and max out on the amperage or do multiple beads? Thanks
Reply:Thanks
GMT+8, 2026-1-2 13:45 , Processed in 0.098249 second(s), 18 queries .
