Vintage drill press
发表于 2021-8-31 22:12:18 | 显示全部楼层 |阅读模式
Old craftsman works well, what year?Sent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:paid 100.00 deal or no deal?Sent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:What the best way to clean the main postSent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:Sandpaper to start, thats gonna be a fun project
Reply:What can I use to degrease itSent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:1939 around that, bearings are common at a bearing store ,clean and paint.
Reply:I just took mine outside and pressure washed all the oil, grease and chips off of mine.  Then blew it off, re-greased and oiled it.  Some brakeclean and a rag or even foaming engine wash with a hose would work if you don't have a pressure washer.
Reply:Thanks I appreciate it! Already drilled my car seat brackets with it, no wobble or driftSent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:i'd say its a great deal providing it works good, and theres not excessive quill side play.
Reply:Im a newbie define quill.side play. Theres no run onSent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:the neck part/chuck that slides up and down out of the casing/ housing.  noticable side movement would point to being wornLast edited by 123weld; 03-15-2016 at 10:47 PM.
Reply:Spray with oven cleaner and hose it off, let the oven cleaner soak for awhile to eat through the yuk. Oven cleaner is pretty good as a degreaser and is cheap. Industrial oven cleaner is sold at reasturant supply places, it works the best.
Reply:Originally Posted by 123weldthe neck part/chuck that slides up and down out of the casing/ housing.  noticable side movement would point to being worn
Reply:Originally Posted by ckobeskoThanks thats what I.thought, no play at all. Ill try to.post a video if I can. Sent from my SCH-S968C using Tapatalk
Reply:I would buy it!  Looks like a cool piece of history.-JessForney C5 Arc WelderLincoln Idealarc 250-250 Ac/Dc Arc WelderMiller Bobcat 225g PlusLincoln PowerMig 200Forney O/A Rig
Reply:I only.paid 100 ,thought it be better than the harbor freight. Putting it to use now.Sent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:It will outlive the Harbor Freight drill press ten times over.-JessForney C5 Arc WelderLincoln Idealarc 250-250 Ac/Dc Arc WelderMiller Bobcat 225g PlusLincoln PowerMig 200Forney O/A Rig
Reply:Looks fun.  Might be better than hf, at least at 100 bucks? How do you adjust the table height?   Has it been repaired by brazing?  How low will it spin?  Looks like it could be prone to tipping forward-- bolt it or add longer base.
Reply:I imagine the Chuck is better than any hf Chuck.
Reply:The table has no indication of prior welding. The table has a handle in the back it will adjust right to the chuck. Sent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:It should be bolted to the floor although if rhe base is turned correctly it is quite stableSent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:It was made by Dunlap for Sears.Lots of good info here,http://owwm.org/index.php
Reply:So when I have this all cleaned any specific paint and primer I should considerSent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:I'm sure there are a lot of guys here that would say Miller blue.......myself included
Reply:That would be coolSent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
GMT+8, 2026-1-2 13:49 , Processed in 0.123417 second(s), 18 queries .
