Hypertherm 800 3 phase wired into 1 phase????
发表于 2021-8-31 22:12:17 | 显示全部楼层 |阅读模式
Have anyone here wired a 3 phase plasma cutter into a 220 1 phase by any means? it is possible or practical? Thanks.Last edited by QCTechInsp; 03-19-2016 at 03:05 PM.
Reply:I'm sure it could be done..  I was looking at converting a welder, but was told that I better have a lot of time and money to do it.  Best of luck -JessForney C5 Arc WelderLincoln Idealarc 250-250 Ac/Dc Arc WelderMiller Bobcat 225g PlusLincoln PowerMig 200Forney O/A Rig
Reply:Should be able to run on single phase. Manual:https://www.hypertherm.com/Xnet/libr...file=HYP104423Hobart Beta-Mig 250T-D Cutmaster 81Miller Maxstar 150STLMiller T-Bolt 225 ACChicago Electric Mig 151Hobart RC-256 Haas-Kamp Conversion(sold)
Reply:Originally Posted by tjb836Should be able to run on single phase. Manual:https://www.hypertherm.com/Xnet/libr...file=HYP104423
Reply:Originally Posted by QCTechInspwell..the problem with the "should be"is that if it dont then I would be left without a chunk of money with something I cant use. For what I know , it can be done with electric motors, but electronics inside a board may work differently than just a motor. This model have one that comes with both 1 and 3 phase option, but the one I may buy have only 3 phase specs on the sticker , so it would have to be a different type of conversion , if it would at all work. No one from Hypertherm that could answer this one straight???
Reply:SINGLE-PHASE AND THREE-PHASE POWER CONFIGURATIONSAll 208/240/480V Powermax800 power supplies are shipped for single-phase operation.All 200/230/400V Powermax800 power supplies are shipped for three-phase operation.However, all Powermax800 power supplies except the 400V CE and 600V power supplies can operatefrom either a single-phase or three-phase input. The 400V CE and 600V power supplies operate onlyfrom a three-phase input.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:^^^^ There ya go.I guess I was too lazy and just linked the entire manual.Last edited by tjb836; 03-19-2016 at 06:40 PM.Hobart Beta-Mig 250T-D Cutmaster 81Miller Maxstar 150STLMiller T-Bolt 225 ACChicago Electric Mig 151Hobart RC-256 Haas-Kamp Conversion(sold)
Reply:QC,In case you weren't aware of it, there is a Hypertherm specific section here that Jim Colt from Hypertherm checks in on regularly.That being said, the Powermax 800 manual that tjb836 posted the link to is quite clear on which versions of the PM800 can and cannot be wired single or three phase and the high voltage units that are three phase only as indicated by the information mechanic416 quoted out of the same manual.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thank you guys for the quick reply. For my luck I think that the one that I was interested is the 3 phase only model after those clarifications. Same thing happening with a cut 42 , which is showing in its plate as 3 phase only. My question I guess was more along the lines that even if one plasma cutter is only 3 phase, if there is a way of ,by maybe some external rectifier or some other way of wiring them , to make them operable in 1 phase, even if it comes designated only as 3 phase. I know many here are electrical wizards and maybe one of you have done it. I know it can be done with motors. I guess no one here have done it or its not possible. Guess will have to let those 2 go. Thanks again.
GMT+8, 2026-1-2 12:05 , Processed in 0.103464 second(s), 18 queries .
