Anyone familiar with this welder?
发表于 2021-8-31 22:12:15 | 显示全部楼层 |阅读模式
I just bought this thing and can't seem to find any info on it. Just curious if it an ok welder for garage hobbies. Thanks.
Reply:I've not seen that particular one, but it's just an old transformer based welder - probably work just fine I'd recommend running it on 230 volts - more power is always better Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:You might want to clean out the dust and dirt. That would help it to stay cooler. And run it on the 230 volts.Klutch 220si mig , stick, and dc tigHobart 140 AHP ALPHA 200X 2016Lotos LTP5000DSmith O/P
GMT+8, 2026-1-2 12:04 , Processed in 0.075642 second(s), 18 queries .
