Idealarc tig 250
发表于 2021-8-31 22:12:14 | 显示全部楼层 |阅读模式
I was given a Idealarc tig 250 that was hardly used. The tig torches all have gas valves on them, do I have to use this type or can I use one without. I do have the foot pedal with it. Any help would be great thanks Brian
Reply:Pics please.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:it its like my machine then no you don't have to use a valve. the machine has a gas solenoid in it that controls the flow… does the machine have a separate connection for gas in and out?a pic would help a lot- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:It does have a hook up for a gas line.
Reply:The gas lines are at the bottom. I'm in the process of taking welding classes, this was given to me so in the process of cleaning it up so I can use it.
Reply:The solenoid may be bad, and hence the valved torch. Just check it all out.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:I had a Lincoln Dialarc 250/250 TIG stick for about 10 years. It's a great machine. Most of them came from the factory with both a gas and a water solenoid. You should look for them and see if they are working. They could have dirty connections or possibly they could be corroded and stuck. I used mine with a cooler that was plugged into the face of the machine so that it was on all of the time that I was welding.Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
Reply:Thanks for the help, I just need to check everything out and give it a try.
GMT+8, 2026-1-2 12:06 , Processed in 0.116912 second(s), 18 queries .
