Hand-held tungsten grinders?
发表于 2021-8-31 22:12:11 | 显示全部楼层 |阅读模式
I've been using a regular bench grinder to sharpen tungsten, but recently learned that due to contamination, it may not be the best method.  Came across a hand-held sharpener today in a local pawn shop, an Arc-Zone Sharpie.  I don't know anything about these types of sharpeners, other than they appear to be expensive.  I can probably get the sharpener for around $80, and it comes with a couple extra grinding wheels.  Would it be worth it at this price, or would I be better off getting a small (and cheap) grinder to use as a dedicated sharpener?
Reply:This was Zap's idea, works great!  Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I have used bench grinders as well as dedicated diamond wheel grinders. I prefer a bench grinder. I can put a nice point by hand but chuck it in the drill and and you can get a nice point, and quick. Honestly I wouldn't worry about contamination… have you had issues with contamination? Most people just use one wheel for tungsten only to eliminate any issues.- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:Once you grind the shape you want you will want to polish it on a 120 flap wheel or higher. I know a guy that uses a 400 grit grinding wheel on his bench grinder and an even finer  wheel then 400 grit
Reply:I have been looking for 1 of those really small bench grinders that only have about a 3 inch wheel
Reply:you guys and your 'contaminated' tungsten.
Reply:Originally Posted by TimmyTIGyou guys and your 'contaminated' tungsten.
Reply:I have one and I can't live without it.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
GMT+8, 2026-1-2 12:02 , Processed in 0.367899 second(s), 18 queries .
