Weekend table project
发表于 2021-8-31 22:12:09 | 显示全部楼层 |阅读模式
I decided this weekend I needed to build an end table for use on the back porch.  Made from 1" angle and 1" square tubing.  I welded a nut to a washer and then welded that to the bottom of each leg so I could add leg levelers.  The top is a piece of pine with a couple of coats of spar urethane. Attached Images
Reply:nice tight corner's chief. what kind of machine did you use?i.u.o.e. # 15queens, ny and sunny fla
Reply:Looks nice man!
Reply:Welcome.  looks good.30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Nice work!I have some granite I have been going to make some patio tables from. Thanks for the reminder! Welcome to the forum!GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by docweldernice tight corner's chief. what kind of machine did you use?
Reply:Thanks everyone for the kind words.  I'm not a very good welder but I'll keep working on my welding skills, until then I guess my grinding skills will keep improving.
Reply:Originally Posted by harleychiefThanks everyone for the kind words.  I'm not a very good welder but I'll keep working on my welding skills, until then I guess my grinding skills will keep improving.
GMT+8, 2026-1-2 12:04 , Processed in 0.080451 second(s), 18 queries .
