Bought a Welding table
发表于 2021-8-31 22:12:08 | 显示全部楼层 |阅读模式
So i picked up my new welding table, not really a project but will make some mods in time. it measure 61"x48" and has a 1/2" top. It was a machine base of some sort Has all the heavy duty leg levelers. Figured it weighs in around 500#. It has some holes in it but I will manage. Also has a bunch of tapped holes that might come in handy for something lol. Also has a stainless steel sheet attatched to it that has the same pattern as the table top( which i removed). What you all think? Attached Images
Reply:Looks like a nice find. I have a portable table...probably just as well- any flat surface at my place tends to gather crap!
Reply:Not a bad find. Looks very sturdy.HF 90 Amp Flux Core Customized.
Reply:Stainless sheet would make a great lower shelf with a bit of cutting.  30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Nice find.
Reply:Nice. Grab some scrap plate and fill the holes. Should be pretty easy
GMT+8, 2026-1-2 12:05 , Processed in 0.080825 second(s), 18 queries .
