Suggestions needed
发表于 2021-8-31 22:12:06 | 显示全部楼层 |阅读模式
I have access to these 2 cubic feet aluminum cylinders at work. They contained a non flammable gas. Hate to throw them away. Any of you smart folks out there have suggestions for projects or re-purposing these beautiful cylinders.Thanks, Attached ImagesHobart 200 MVPEverlast 200DXEverlast PP50 PlasmaComplete Machine ShopToo many 2 wheelers
Reply:Send them to me? Yea I had one and cut the top and bottom off and made seat pedastal for my alu. fishing boat and an ashtray from the bottom and a heavy duty funnel from the top. Just what I needed at the time. Would make good wind chimes also.
Reply:Cut off bottom and make a gong ? I don't know how the sound would be.
Reply:Chop the bottoms off polish up and sell them to the backwards cap wearing Honda civic drivers... (tail pipes if you didnt guess it  )
Reply:I live by if its free its for me...worse case scenario....cut them in half for scrape..but im sure once you stare at them for awhile..a use will come to mind....what are the dimensions of them and how many can you get?Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Epic, compressor charged, super soaker water gun?Aluminum wouldn't ring as well as steel cylinders for wind chimes, I wouldn't think.  More of a tink-tink.AHP AlphaTIG 200DX (2nd Gen)Lincoln WeldPak 3200HD Bird Poop GeneratorLotos LTP5000D Plasma Cutter
Reply:Get some air fittings and use them for compressed air tanks for airing up tires.Make some small BBQ pits out of them.
Reply:super sized thermos?we've all had those morningsMiller Spoolmate 200 w/t S-52 WirefeederMM 211'09 Miller Trailblazer 302
Reply:you could shoot them. That's always fun.
Reply:Make a sure-shot out of them.Sent from my iPad using TapatalkDynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
GMT+8, 2026-1-2 12:06 , Processed in 0.347184 second(s), 18 queries .
