gas solenoid for lincoln
发表于 2021-8-31 22:12:05 | 显示全部楼层 |阅读模式
Looking for a gas solenoid for a lincoln idealarc tig 250/250 . I found one place on the internet but they want way too much $. Let me know. thanks
Reply:Hey, Just want to speed the word. Instead of buying a whole new valve and body I just read the name of the solenoid Manufacturer...Peter Paul electronics...they sent me the valve (about 24$)and I installed it on the body. It works fine. Much better then spending 200$            Just google Peter Paul electronic and you probably can find a distributor in your area on their site. valve# OW22BGVVOLTS 120 50/60WATTS 10PSI 100ORIFACE1/8SER *BLalso on back M12648
Reply:Good stuff..........look around surplus stores, garage sales too, before unloading $200 on something that can be found elsewhere.Just as I did in post #8 here:http://weldingweb.com/vbb/showthread.php?t=35108
Reply:Always good to know about cheaper ways to valve welding gases.I thought the nic "lilredex" was familiar. I've seen your LP trucks in the Raso forums.
GMT+8, 2026-1-2 12:05 , Processed in 0.801629 second(s), 18 queries .
