I have found on this site in the stickey as well as in a serch of the forum there are several diff orders listed, I want to be as sure as I can what is the correct order for the plug wire's on the mag cap?1997 SA 250
Reply:#1 o #3 o #2 o #4 oDoes this do any justice? The firing order is 1-3-4-2, looking at the cap the top left is number one and go in a clockwise rotation
Reply:Firing order is 1 3 4 2 in a clockwise rotation as 60redfacer stated viewing the mag from the rear of the engine looking forward.As denrep has stated many times, it really doesn't matter which cap tower you start with as long as the wire for the cylinder on the compression stroke is on the tower that the mag rotor is lined up with. Then just install the remaining three wires in the correct firing order above.However, if you want to get technical, Fairbanks-Morse #1 is the upper inside tower while the American Bosch is the upper outside tower.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thank you both vary much I am sure it is o.k. I was just checking so I can eliminate everything I feel like this thing is running under load with nothing going on I put a cable control on it at the same time I installed the weldmart e-z idler and it seems to run louder then before I don't have anywhere local that is experienced with these to tell me so it has been a long process of elimination Kerry at cable control walked me threw the wires and that all seems to check out but I keep on keep in on1997 SA 250 |
