Mig Conversion K2526-1
发表于 2021-8-31 22:12:02 | 显示全部楼层 |阅读模式
What parts do I need to build my own rather than buy this Lincoln kit?
Reply:Right from lincoln.For MIG (GMAW-gas-shielded solid wire) welding. Includes two .025÷ (0.6 mm) Contact Tips, gas nozzle, 2 lb. spool of .025÷ SuperArc® L-56 mild steel MIG wire, gas regulator for Argon and Argon-blend gases, adapter for CO2 cylinders, gas solenoid (115V), hoses, connectors and instructions.This is what is in the kit. The gas valve comes with gas fitting and wiring harness.If you have a regulator already You can find a gas valve and fittings some where. plastic hose to connect the valve to the gun block. Wire it in to the pcb and it should work.Look at all you get for the price Then look at your time to chase all the different parts you need, from several stores. Then decide what is  best for you.
GMT+8, 2026-1-2 12:45 , Processed in 0.104177 second(s), 18 queries .
