Alum options for 255
发表于 2021-8-31 22:12:02 | 显示全部楼层 |阅读模式
I just picked up a new Powmig 255 and im curious what everyones doing for alum? Im assuming spool guns but im not sure if you can run push pull setup off these things? without pulse I know its not ideal but just curious what everyones doin?
Reply:i added a prince spool gun to mine. have a certified welder teaching me how to weld aluminum. he seems to like it.one thing for sure alum. is a different breed of cat. this old man has trouble moving fast enough. one moves a lot faster than steel.
Reply:Delete
Reply:Down load the owners manual and read the options page. It will tell you all that can be connected to it.
GMT+8, 2026-1-2 12:45 , Processed in 0.098499 second(s), 18 queries .
