Need Help Resurrecting My Shorthood
发表于 2021-8-31 22:12:01 | 显示全部楼层 |阅读模式
I bought an SA200 Shorthood the other day and still need a little help bringing it back to life. Ser. # is A249576 & code is 1903 (1951 model) It was built with electric start but the starter, etc. is missing and the PO was crank starting it. I want to reinstall the electric starter. What will I need?  What starter, alternator,etc.  I think this thing was originally a 6V system, so am I going to have issues using a 12V battery, etc? I can use all the help I can get!  I'm electrically retarded. Thanks!!Last edited by goinssr; 12-13-2010 at 04:39 PM.StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:Probably the best advice I can give would be to get in touch with these people:  http://www.billswelderrepair.com/From what I understand they are very knowledgable, helpful, and tend to go out of their way to help someone in need with their machine.  Good luck!A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:As for the starter, to my knowledge, is the same as the one on a redface too. You can put a one wire alternator (12 volt) and it will work great
GMT+8, 2026-1-2 12:47 , Processed in 0.094072 second(s), 18 queries .
