查看: 13|回复: 0
weldmart ez idler
发表于 2021-8-31 22:12:01 | 显示全部楼层 |阅读模式
does any body have any experiance with these units? I am having some trouble, The selanoid dosent release when the board is turned off. it pull's the plonger in any time the machine is running. turn the machine off and the selanoid let's go of the plunger.Help ! thank's in advance, Larry in not there on saturday's .1997 SA 250
Reply:Does it idle up and down, like if you strike an arc?
Reply:I couldn't tell you I am working through this one step at a time and what ever the cause this is not operating correctly . With the board of and no power to the plunger it should release1997 SA 250
Reply:If it is a solenoid, it should move freely when power is removed.If it is a liner motor, it won't move with out power.You need to find out which type you have.
Reply:yes it should. Have you pulled the plunger out of the coil to see if it's rusted or gummed up?
GMT+8, 2026-1-2 14:31 , Processed in 0.133296 second(s), 18 queries .
