prince xl
发表于 2021-8-31 22:11:59 | 显示全部楼层 |阅读模式
anyone running one or ran one how do you like it ? thanks for any info 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:OK gun. If you are going to run 5356 AL You will want to change to insulated drive rolls.I have seen 5356 AL that has been out of the package for a while. Take the teeth right off the drive roll real fast, MK Products recommends switching to insulated drive rolls when welding only with one size AL and your not changing around a lot.
Reply:any reason why you consider it as OK vs any other lincoln compatible gun ?350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:My friend has a Prince XL he runs off his Trailblazer.  He loves it.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:thanks desertrider can you tell i really wanna make sure my grand is spent on the right choice 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Can't be too careful with that money these days....MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2026-1-2 12:45 , Processed in 0.109078 second(s), 18 queries .
