esab handy plasma 125
发表于 2021-8-31 22:11:57 | 显示全部楼层 |阅读模式
does anyone have any experience with this machine good and bad.i am looking to buy my first plasma cutter and only have 110v to work with..thanks
Reply:Originally Posted by parrottgarydoes anyone have any experience with this machine good and bad.i am looking to buy my first plasma cutter and only have 110v to work with..thanks
Reply:ESAB is a reputable company.Buy extra consumables when you order as the small PCs with the built in air eat them up quickly since there is no way to keep the air dry.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I love my hobart 250ci and selling it because I just upgraded, but if I ever need another 110v with built in compressor I would buy another hobart no questions asked. I did prefer the torch on the thermal dynamics drag-gun I had, but that thing was also 60pounds!Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:The drag gun plus Thermal Dynamics machine has a built in condenser/water removal system. It is a 35 amp cutter with built in compressor that runs on 230v. Weight is 76 lbsThe air cut 15 Thermal Dynamics machine is a fixed 15 amp cutter that runs on 120v. It also has a built in compressor. weight is 29 lbs. No condenser for water removal on this unit.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2026-1-2 12:47 , Processed in 0.075572 second(s), 18 queries .
