need help in az
发表于 2021-8-31 22:11:56 | 显示全部楼层 |阅读模式
I have a chunk of 2 inch by 1/4 wall DOM that i need to cut a 1/2 inch wide slit into it. and unfortunately i have no way of cutting it. if anyone in the phoenix area has a way to do it that would be great. basically i need it cut so that i can slip a 1/2 inch thick piece of plate into the slot cut in the end.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:Primer cord???????
Reply:lol i thought about a 5.56 but i need it a bit more accurate.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
Reply:Originally Posted by NoBigDeal FabI have a chunk of 2 inch by 1/4 wall DOM that i need to cut a 1/2 inch wide slit into it. and unfortunately i have no way of cutting it. if anyone in the phoenix area has a way to do it that would be great. basically i need it cut so that i can slip a 1/2 inch thick piece of plate into the slot cut in the end.
Reply:I will be back in town on Tuesday. Should be able to mill it. I will pm you my number. If you still need help give me a call in the afternoon.From the desk of Kevin CaronTrying to be the best me I can!www.kevincaron.comAHP Alpha Tig 200x MillerMatic 251Miller Syncrowave 200
Reply:Originally Posted by dave powelsonA cutoff wheel in angle grinder for the edges, then regular wheel to grind out the balance.
GMT+8, 2026-1-2 12:46 , Processed in 0.108178 second(s), 18 queries .
