查看: 13|回复: 0
Torque Wrench question
发表于 2021-8-31 22:11:56 | 显示全部楼层 |阅读模式
Manual reads: 20lbs/ft + 90˚what is +90˚Torque to 20lbs and then turn another 90˚ ?Thanks.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Is this a manual written in China?Blackbird
Reply:That is correct,  torque to setting then add the degrees.  If they are torque to yield bolts then you will need to use new bolts to get the torque correct.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by soutthpawThat is correct,  torque to setting then add the degrees.  If they are torque to yield bolts then you will need to use new bolts to get the torque correct.
Reply:Husqvarna MC.and to make everyone cringe... my buddy misread the directions and torqued to 90lbsGonna need a new case doh!he knows it was a BIG mistake and showed me the manual where he skipped over the 20 and read 90 as the specs.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I personally loathe torque to yield fasteners.   Having to buy new bolts every time you dissasemble something is a real big added pain in the azz.   The other being for the reason your buddy feels dumb.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by Broccoli1and to make everyone cringe... my buddy misread the directions and torqued to 90lbs
Reply:I think they make a torque angle gauge for that. I seem to remember one when I was a mechanic for Oldsmobile. I just can't remember if I ever bought one. I will have to look in the drawer with all of the "tools I bought, but will proly never use again!""Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:http://www.ntxtools.com/network-tool.../OTC-4554.htmlYea they make em
Reply:Too bad it's not in your area. http://nh.craigslist.org/tls/3325149629.html  Good price.Otherwise fleabay has some, usually. Measures the torque and angle.
Reply:Yeah I have an angle guage, got it off the snap-on truck. It was about $80. And makes it so much better to get the correct Degrees out of the bolt. Especially if you only have about 15 degrees of movement in a tight spot.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.
GMT+8, 2026-1-2 16:06 , Processed in 0.141422 second(s), 18 queries .
