Cup size
发表于 2021-8-31 22:11:49 | 显示全部楼层 |阅读模式
Hello, greatly appreciate tips ....What cup size is recommended for tig welding 20 gauge 316L or 308L using .040 tungsten? What about a gas lens? Thank you!
Reply:Depends on allot of things,  joint type, travel speed, amperage... What colors are allowable? Going to have a heat sink?  I would use a #6 cup,  prefer a gas lens but it may not be required.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Thanks SquirmyPug. Your right. cup 4,5,6 with gas lens as per yourself, CK, and other additional sources.
Reply:Am I the only on that got fooled by the thread title and expected boob jokes?Be wary of The Numbers: Figures don't lie,. but liars can figure.Welders:2008 Lincoln 140 GMAW&FCAW2012 HF 165 'toy' GTAW&SMAW1970's Cobbled together O/A
Reply:I find a D cup to be the minimal acceptable cup for anything I do!    There, feel better Mike?Miller Multimatic 255
Reply:D works for me!!!!
Reply:dd             ......................Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Originally Posted by mike837goAm I the only on that got fooled by the thread title and expected boob jokes?
Reply:My problem is that as the cup size goes up my travel speed increases and my working piece gets hotter!I really have no idea what I am doing.Two Shop Cats (not Bobcats...real cats)Miller DialArc 250 AC/DCScratch-Start TIG SetupMIG 175Plasma CutterO/A
Reply:That is a normal problem wannab1. Your not alone
Reply:Originally Posted by wannab1My problem is that as the cup size goes up my travel speed increases and my working piece gets hotter!
Reply:I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Thanks Dave. At least I'm not disappointed that someone didn't post up picts with a title like that. .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:You sexist pig.It doesn't matter what cup size she has. If she can lay a bead, she can lay a bead. TIG is not gender specific. HaLincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:OK back to tig welding ............I like a larger cup for AC  with higher amps than 150  1/8 in. tungsten....Unless there is a reason to extend the tungsten I can't see a reason for Gas Lens.....Since I run a lot of Helium with my parts I have found running a higher flow rate is necessary to get good coverage......Most of my aluminum stuff is done with a 6 std cup....2% Lanthanated Last edited by B_C; 01-01-2015 at 10:13 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
GMT+8, 2026-1-2 16:06 , Processed in 0.169140 second(s), 18 queries .
