How much would a 3x3 welding table on caster sell for?
发表于 2021-8-31 22:11:45 | 显示全部楼层 |阅读模式
I have a piece of scrap 3x3 3/8 in plate from a welding table that I made. I bought a 3x9 piece and cut it down to 3x6 and now I have this 3x3 piece. I was thinking about getting some square tubing for this instead of angle like I used for my table, putting it on casters, painting the frame of it, and drilling holes in a 2x2 or 4x4 grid so you can use clamps like the stronghand tables. Anyone know how much I could sell it for? Just looking for a fun little project that might make some money haha. Thanks guys!Building a 94 crew cab Chevy long bed dually welding truck. Has a Cummins, Ford ZF6 transmission with custom made adapter plate, NP271, Dodge Dana 60 SAS, Chevy 14 bolt rear, 8 inch suspension lift, with 3 inch body lift. Check out my build thread!!
Reply:around here (Mn) about $75........
Reply:Hmm, I've seen some hack job tables about this size go for $300 around here lol. I guess if I can't sell it then I'd have a little table to roll around?Building a 94 crew cab Chevy long bed dually welding truck. Has a Cummins, Ford ZF6 transmission with custom made adapter plate, NP271, Dodge Dana 60 SAS, Chevy 14 bolt rear, 8 inch suspension lift, with 3 inch body lift. Check out my build thread!!
Reply:The hard thing about making a profit on a welding table is that pretty much anyone who needs one can build one.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by GravelThe hard thing about making a profit on a welding table is that pretty much anyone who needs one can build one.
Reply:Originally Posted by SteThat's true. I just want to reasonably price it, and if no one wants it I can keep it for myself! Won't be a loss if it doesn't sell because it would be made it if material I have in my garage already, well besides the casters.
Reply:It depends on location. I sold a 30'' x  48 '' x  1/4'' table top  with 2'' x 2'' angle iron frame for $250.00. I bought it cheap and added a lower shelf and framework.
Reply:Originally Posted by GravelIf you areconly having to buy casters then go for it. Like you said, worst case scenario you can keep it.Post up the build progress.   < root beer
Reply:Originally Posted by BD1It depends on location. I sold a 30'' x  48 '' x  1/4'' table top  with 2'' x 2'' angle iron frame for $250.00. I bought it cheap and added a lower shelf and framework.
Reply:max of $125.....$100 on average.IMOJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Here is the start on my 3x6 table, no welding has been done yet but hopefully I'll get my welder back soon!Here is the angle all cut to size:And here is the table, it's going to have another support in the middle. I just want to tack these down first then put the support in.Building a 94 crew cab Chevy long bed dually welding truck. Has a Cummins, Ford ZF6 transmission with custom made adapter plate, NP271, Dodge Dana 60 SAS, Chevy 14 bolt rear, 8 inch suspension lift, with 3 inch body lift. Check out my build thread!!
Reply:I hope you dont weld it where it sits. Even I dont weld near gas tanks or gas cans, and i've been married for 23yearsSafety 3rdGump
Reply:Originally Posted by GumpI hope you dont weld it where it sits. Even I dont weld near gas tanks or gas cans, and i've been married for 23years
Reply:I also hope you are planning to weld the frame together and then bolt the top on the frame. If you start welding the frame to the table top, you will distort it. How much will depend on how much weld you put down. Best option is bolting. Later on, if you come across a thicker piece of plate, you can unbolt the one you have now and replace it.
Reply:Make it a grinding station.  Bench grinder and belt grinder on adjascent sides, with a beefy vise on the opposite corner.  Put racks underneath for angle and die grinders, wheels, burrs, belts, etc.  Mount a double gang box with 4 receptacles on the bottom side.You didn't build that.'85 Miller AEAD-200LE
Reply:Originally Posted by anickodeMake it a grinding station.  Bench grinder and belt grinder on adjascent sides, with a beefy vise on the opposite corner.  Put racks underneath for angle and die grinders, wheels, burrs, belts, etc.  Mount a double gang box with 4 receptacles on the bottom side.
GMT+8, 2026-1-2 15:37 , Processed in 0.124309 second(s), 18 queries .
