I have the power!
发表于 2021-8-31 22:11:44 | 显示全部楼层 |阅读模式
That's right,  a shiny new addition to the shop today,  150 amps of juice.Color me happy. Attached ImagesRegards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by Robert HallThat's right,  a shiny new addition to the shop today,  150 amps of juice.Color me happy.
Reply:150 amps - now we're talkin Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Nice!!!!
Reply:glad you got it done and sorry it was out of my league to help you Rob...MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC"I'd like to believe as many true things and as few false things as possible"
Reply:That's a lot of power.       Tahat will be very useful.
Reply:Was it done buy an electric professonal , was it inspected , were you licensed , was any body looking when you did this ,what if it burns down, JUST KIDDING .But all that power just for a HF 110 volt mig. Enjoy it ,I did the same thing about 6 yr's ago , all 10 gauge wire ,steel conduit
Reply:Not a problem, it was going to get done one way or the other. And thank you for the attempt.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by gxbxcWas it done buy an electric professonal , was it inspected , were you licensed , was any body looking when you did this ,what if it burns down, JUST KIDDING .But all that power just for a HF 110 volt mig. Enjoy it ,I did the same thing about 6 yr's ago , all 10 gauge wire ,steel conduit
Reply:Hunnit-fiddy? Awesome! GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Throw them damn 3-ways in the garbage, cause you don't need them no more! Ha, nice man! That'll round a couple of corners!I have something strikingly similar in my garage cept it's two 50's and a 20.-Niche
Reply:And like a good pair of pants,  I have room to expand.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:GFCI protected? Where's the stickers?An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:now that you got more power you need more equipment just to keep things balanced.i.u.o.e. # 15queens, ny and sunny fla
Reply:Some guys are just good with electricity that looks great!!! So how did u accomplish this? I know little about Electric. Did you start with a big breaker in the main panel and run heavy ga to the 220 then off that run to the outlets?Located In SE OklahomaLincoln Mig 135Hobart Ironman 230 Mig5x10 CNC Table with DTHC & FTHypertherm PM65 on the tableMiller Bobcatwww.caneyagequipment.com
Reply:Originally Posted by Willie BGFCI protected? Where's the stickers?
Reply:Robert Hall: "It's the garage. I'll just just remember not to shower with it." Come on, you know very well it needs GFCI protection if it's 120Volt 15 or twenty amps.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:Now you gotta get a few of these, and you're in business"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by Willie BRobert Hall: "It's the garage. I'll just just remember not to shower with it." Come on, you know very well it needs GFCI protection if it's 120Volt 15 or twenty amps.
Reply:A carpenter bitched to me about the temporary service I installed. He said it had four GFCI outlets that were no good. I asked if four tripped? A: Yes they did! I asked if he used the same cord he was using the day of our conversation. A: Yes! I looked down, at no point in its length was it free of visible damage. At that moment it was shut in a metal door. I replied; "and you're sure all four ground fault interrupter outlets were no good?" He was very angry!An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
GMT+8, 2026-1-2 15:39 , Processed in 0.098760 second(s), 18 queries .
