.025 ER70S-6 wire?
发表于 2021-8-31 22:11:32 | 显示全部楼层 |阅读模式
I can't find 12lbs spool of .025 wire anywhere - only .023. Can I run this with my .025 drive roll? I can't even find a .023 drive roll for my Lincoln Weld Pak 140.
Reply:0.023 and 0.025 are for all practical purposes the SAME.  Same welding parameters, same drive rolls on the machine.  The best laid schemes ... Gang oft agley ...
Reply:Well that makes things easy. I'll use the same tips/drive roll for .023 and .025. I'm trying to find a store near me that sells 12lbs of either. I finally found a online store that sells .025 but I would have to pay in shipping equals the cost of a 2lbs roll.Thanks
Reply:Mutant If you go to the top left and add your location to your User CP, we'd all know roughly where you are located. Then someone in your area might be able to offer up a suggestion as to who in your area might carry that wire in stock..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thanks for the heads up DSW. I went ahead and filled it out. I actually found a welding supply store 2 blocks from where I work and they have 11lbs spools of .025 for $44 bucks. Probably not a bad deal for NYC. Never thought to look in Manhattan for supplies.
Reply:Hey mutant,Here's an E-Bay store you can get (2) rolls of .023, 10#, for lass than $35 shipped. I have some... works great.Dennyhttp://cgi.ebay.com/Mig-Steel-Weldin...item45f5ad1b67Complete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:Wow! Thanks a ton Denny, that's a pretty good deal.
GMT+8, 2026-1-2 15:41 , Processed in 0.073142 second(s), 18 queries .
