SA-250 quit running
发表于 2021-8-31 22:11:32 | 显示全部楼层 |阅读模式
My machine quit running on me the other day it has a deutz engine in it.the only thing I can find is it keeps blowing the fuse that the reset button has on it. Just wondering if any one has any ideas? Thanks
Reply:need the code number so we can look up your machine.If you need the operators manual get one from lincoln's web site.If you want a clear electrical diagram for your machine, you can call Lincoln and they will send you one.
Reply:Thanks for the reply! The Model#SA-250 F3L1011. Code# 9805 HP. Serial# V1930318394  Any help or leads on where to start is greatly appreciated.And another question the toggle switch that switches it on and off feels like it could be going bad just wondering if maybe that could cause the fuse to be blowing?I just got in for the holidays from working out of town so ain't had a chance to fool with it yet planning on getting it off the truck tome and pitle with it.   Thanks for any help
GMT+8, 2026-1-2 15:39 , Processed in 0.096142 second(s), 18 queries .
