looking for a high freq for lincoln weldnpower 225
发表于 2021-8-31 22:11:30 | 显示全部楼层 |阅读模式
as stated i'm looking for a high frq unit. do they have one that would have a remote set up built in??? i dont have a remote on the portable and would like one for aluminum. any ideas or suggestions would be great, thanks
Reply:Question for the 7a749,  do you think I could build a contactor box using a dc solinoid  continuos duty,.rating of 200 / 250 amp,  Iam just starting out with an old lincoln HI FREQ box, and dont want to spend much money,  till I can see how well I can tig,  Thanks  Eric
Reply:I'm not Steve but sure.  All you need is a 60-75amp three pole (three phase) motor contactor with a coil of the appropriate voltage.  Make a jumper bar to connect all three legs together on the input and output sides to connect the weld power cables to.That's how many welding power units are configured.  I've picked the above size up off eBay for under $50.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55I'm not Steve but sure.  All you need is a 60-75amp three pole (three phase) motor contactor with a coil of the appropriate voltage.  Make a jumper bar to connect all three legs together on the input and output sides to connect the weld power cables to.That's how many welding power units are configured.  I've picked the above size up off eBay for under $50.
Reply:Originally Posted by kubotakidQuestion for the 7a749,  do you think I could build a contactor box using a dc solinoid  continuos duty,.rating of 200 / 250 amp. . .
Reply:Originally Posted by denrepDuaneB - Are AC line contactors sometimes used to stop/start welder secondary?
Reply:Originally Posted by duaneb55Quite often denrep and not just on my homemade suitcase feeder either which is switching DC weld power.  They're typically located between the transformer and output rectifier on DC power supplies that use them to switch the secondary current (i.e. MM200).
GMT+8, 2026-1-2 15:40 , Processed in 0.097217 second(s), 18 queries .
