LN 25 Help
发表于 2021-8-31 22:11:27 | 显示全部楼层 |阅读模式
Been a shop welder for almost 15yrs using outer shield wires . Resently ventured out into field work . With a Miller Trailblazer 302 coupled to a LN 25 running .068 NR232 . @ 22-23 voltsSet the miller to CV wire feed mode , set the selector on reverse polarity on the miller and LN 25 . Now heres where I get lost the LN25 has a switch above the feedrolls that can be switched from CV to CC modes . When I set it to CV it wont run for s**t (acts like its way to cold -barely melts the wire ) ,but when its in CC mode ( miller is still set to CV) it will run good ( not as good as it should )and I can put down fairly nice welds . What am I doing Wrong???Last edited by dawg11; 12-28-2010 at 01:39 AM.
Reply:Hello dawg11, you need to have your machine set for straight polarity, meaning the ground should be + and the LN 25 should be connected to the - terminal. As well as that, you should have the 302 set for CV output and the selector switch inside of the LN set for CV, then set the polarity switch on the front of the LN to -.  That should get you on the right track other than dialing in the voltage and the wirespeed. Hope that helps. Good luck and best regards, Allanaevald
Reply:Allen -I have the switch on the LN 25 set to - and the same on the 302 (theres a switch on front of the machine to switch polairty) The LN 25 won't work unless both ( 302 & LN 25)are set the same way . I guess my main confusion comes from it not working when all is set to CV but it works so-so when the 302 is set to CV and the LN 25 is set to CC
Reply:whats the volt meter read on the LN25?
Reply:Bucket - the Ln25 volt meter reads 22 volts
Reply:Originally Posted by dawg11Bucket - the Ln25 volt meter reads 22 volts
Reply:Originally Posted by bucketsounds ok, abit low for me if ocv, when you add volt drop. can you prove the LN25 is ok, by running it on another power source i.e. a mig with swf just connect to output terminals etc.
Reply:Originally Posted by dawg11Should be ok its brand new less than 60 hours on it.
Reply:Hello again Dawg11, I have included a link that may answer some of your questions regarding the innershield process and give you information to come up with the correct machine settings and possibly give you some troubleshooting tips for getting everything working smoothly. Best regards, Allanhttp://content.lincolnelectric.com/p...ure/c32400.pdfaevald
Reply:NR 232 is a flux core self shielding wire. You want the positive weld lead going to the weldment and the negative lead to the LN 25. 22 to 23 volts, you will need around 175 to 195 ipm wire speed. LN 25 polarity switch set to negative. meter must read up scale. This will tell you if your set up right. Both welder and LN25 should be set on CV.You can make a few quick tests. make sure the HI/ low speed switch is working. If you can connect the LN 25 to a non engine welder I have a test for the CV CC  switch.Turn the wire speed up near max. release the feed pressure. pull the gun trigger. listen to the motor. with the motor running switch the cv/cc switch. you should hear a small change in motor speed. another test is to run the motor at a very slow speed and see if the speed is steady. stopping and starting and pulsing could mean bad brushes or a problem with the speed sensor.Remember outer shield wire uses positive voltage and flux core uses negative voltage on the gun. Post your results.
Reply:Originally Posted by aevaldHello again Dawg11, I have included a link that may answer some of your questions regarding the innershield process and give you information to come up with the correct machine settings and possibly give you some troubleshooting tips for getting everything working smoothly. Best regards, Allanhttp://content.lincolnelectric.com/p...ure/c32400.pdf
Reply:Hey THANKS to all for the help in getting this figured out .
GMT+8, 2026-1-2 15:39 , Processed in 0.098943 second(s), 18 queries .
