need help with ranger 8
发表于 2021-8-31 22:11:26 | 显示全部楼层 |阅读模式
I just purchased a used ranger 8 and after getting the motor running I found that it did not have any output. The code number for the machine is 9972 and I have checked the rotor and it has 4.8 ohms and is not shorted to the shaft. i cleaned up the slip rings and the brushes look good. I looked at the pc board and there is four diodes on the bottom of the board and three of them are pretty burnt looking. The number on the board is L4848-2. my question is, what do i need to check before i replace the board, and did it just burn up on its own or did something cause it to burn up.
Reply:Are you sure that's not L8484-2?  The parts break-down shows it as L8484-[ ] ([ ] is for the revision number - in this case -2).Rotor resistance is good and I don't have any information on the control board to give any detailed assistance.  However, if you contact Lincoln on Monday, they should be able to email you the schematics and/or details of the board for you to identify the individual components.As for other things to check, I'd look at field control voltage bridge rectifier D2 for being shorted as a possible cause of a PCB1 failure.If you do get a schematic from Lincoln, let me know and I'll see if I can give any additional specific troubleshooting steps.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:yes your right that number was L8484-2 and I appreciate the help. I have a friend that gave me the name of a place in town that is real reasonable and should be able to help me but i will take you up on your offer if i need to. thanks
Reply:hey just thought id let you know that when i called lincoln about the schematic i talked to their tech line and to say the least they were great. i was realy surprised to find that they offer such a good service to the public. he told me about 6 or 7 things to check and i went home that night and checked them and went the next day to a place that had the board that i needed and installed it. after some carborator cleaning and adjusting the thing runs and welds supper. thanks for the help
Reply:Thanks for the update pabentzler.  It's that kind of knowledge and service one can expect from a top quality machine manufacturer.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-2 15:40 , Processed in 0.111442 second(s), 18 queries .
