gouging with plasma
发表于 2021-8-31 22:11:22 | 显示全部楼层 |阅读模式
I don't own a plasma cutter yet, but plan to get one in the future.  My question is about using plasma to gouge.  Can I use a plasma cutter to gouge welds etc the same as I use my Arcair now?Lincoln 250 IdealarcLincolc 255 PowermigLincoln SA 200 1940's with V4 WiscLincoln SA 200 1974 blackface
Reply:Yes, you sure can.I gouge frequently with my plasma cutter.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Yes, is a typical applicationMauricio
Reply:You bet!  Works awesome!Sent from my C771 using Tapatalk
Reply:I like it better than arcairBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by killdozerd11I like it better than arcair
Reply:Thanks for the replies.   I'm hoping it will be more pleasant to use than arcair.  That thing sure catches my clothes on fire a lot!Lincoln 250 IdealarcLincolc 255 PowermigLincoln SA 200 1940's with V4 WiscLincoln SA 200 1974 blackface
Reply:Make sure you have any special nozzles or consumables for doing gouging with your plasma cutterCEP thats quite true and sometimes you get into a place where you just have to use a torch with a scarf tip because nothing else will get in there and then it starts overheating the tip and popping ..nothing is perfect in all things you get into when doing repair weldingBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:I like it too, mostly for gouging cracks - using only the power needed to get the job done gives it great economy.Like mentioned above, if you need to reach straight ahead CAC is still needed.Matt
GMT+8, 2026-1-2 15:40 , Processed in 0.095958 second(s), 18 queries .
