Tig Lincoln V160 tp
发表于 2021-8-31 22:11:21 | 显示全部楼层 |阅读模式
Hello, I'am writing a message from Belgium because Lincoln is more used in the USA as in Europe.Is this normal, when I switch off the machine, the screen (amperage) flashes a couple of times and also the led of the remote control blinks a couple of time. This takes 10 seconds in total.Thanks and sorry for my poor english.
Reply:Hello klaashaas, I am not specifically familiar with the machine you are speaking about, but I would offer this as a possible explanation. Most of the inverter type machines have some fairly sizeable banks of capacitors as a part of the make-up of their electrical circuitry. Those capacitors act as batteries to a certain degree. Thus, when you turn off the power there is a short bit of time where these capacitors might be "bleeding" down and releasing some residual current. This is likely the reason for the things you are seeing. There are likely others on the forum here who have the same machine as you and can say whether or not they have experienced the same sort of thing. There are also a number of people who are very technically savvy when it comes to Lincoln equipment and could explain the process in detail and also comment on whether your machine is like a lot of others when it comes to the flashing and slow shut-down. Good luck and best regards, Allanaevald
Reply:Your English is fine, klaashaas.  Do you normally speak Dutch or French?  Anywhere close to Spa Franchorchamps? aevald may have answered your question, but as he said, others on the board may own the same machine and add more information.Good LuckTxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
Reply:Thanks for the answer.I speak Dutch, from Antwerpen. That's far away from spa, the other side of the country. Around 200km. HahaBut almost everybody speaks both languages.
Reply:Can you provide a code and serial number  of the welder?ThanksTxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
Reply:Sorry for the late answercode 52038Serial L2110402638Thanks
Reply:okay, will try to get you an answerTxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
Reply:I thought I had already posted [email protected] 24 (8 days ago)to meSounds normal if it welds ok.,  but this product is under our Europe service umbrella. You need to contact Giorgio Bozzano/LincolnItaly@LINCOLNEUROPE for further correspondence pleaseBill Steller    Machine Trouble Shooter                                    SSBN 640 Boat                         From: James Kent/Lincoln Electric/USTo: Bill Steller/Lincoln Electric/US@Lincoln Electric,Date: 10/24/2012 09:13 AMSubject: Fw: Lincoln Electric - Ask the Experts - ResponseTxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
GMT+8, 2026-1-2 15:40 , Processed in 0.106603 second(s), 18 queries .
