Cutting with Natural Gas
发表于 2021-8-31 22:11:17 | 显示全部楼层 |阅读模式
A buddy of mine has lots of natural gas cylinders that look like Large oxygen bottles. They are about the same and size weight as an oxygen bottle and are for sure a high pressure cylinder. He claims they have around 3000psi in them but we have no way to be sure how full they really are. My question is not can natural gas be used for oxy fuel cutting but what would it take to make this cylinder work? It seems that most cng cylinders have around 400 psi like propane and Im curious what type of regulator would be needed to make this work because the propane regulators only go to 400psi. Could i put different fittings on an oxygen regulator and safely use it with the cng? Any advice would be greatly appreciated.
Reply:propane tanks are liquid, nat gas tanks are not. LPG vs CNG. What thread is on the tanks? Is it a CGA 350 valve ?http://en.wikipedia.org/wiki/Compressed_natural_gasmiller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:I dont have the bottle in front of me but iirc it was about a 1/2-1 inch threaded male end on the valve.
Reply:You can certainly cut with CNG, and makers list tips for it. Victor uses the same tips for LP and CNG.http://www.usweldingsupply.com/victor-2-gpn.htmlhttp://www.weldingandgasestoday.org/...rnative-fuels/I'd sacrifice an oxygen regulator for CNG use, BUT I'd ensure it was clearly identified by removing the guage covers and marking the faces legibly with a Sharpie or similar marker. I would NEVER use that regulator for oxygen again without sending it off for professional rebuild to include "oxygen safe" cleaning. (Rebuilds are cheap and less hassle by far then cleaning your own.)Post pics of your cylinder valves.Concoa fitting and nipple chart:http://www.concoa.com/cgachart.html
Reply:Natural gas cannot be stored in liquid form without some serious refrigeration. - MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
GMT+8, 2026-1-2 15:40 , Processed in 0.225833 second(s), 18 queries .
