I must ask my first silly question.
发表于 2021-8-31 22:11:14 | 显示全部楼层 |阅读模式
Can i take my welder through the car wash?Sent from my SM-G920P using Tapatalk
Reply:Sure, why not?  In fact, I must insist that you do. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:You haven't provided any details regarding your welder but sure.  Whether you turn the water on or not is another matter based on what the machine is.To be serious, if it's an engine drive, getting a wash job is not that unusual and depending on the machine itself will determine what areas need to be approached with caution.If a shop type machine, they have been "car washed" by many who work on them on a regular basis and certain precautions need to be taken with regard to control boards, relays, etc.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55You haven't provided any details regarding your welder but sure.  Whether you turn the water on or not is another matter based on what the machine is.To be serious, if it's an engine drive, getting a wash job is not that unusual and depending on the machine itself will determine what areas need to be approached with caution.If a shop type machine, they have been "car washed" by many who work on them on a regular basis and certain precautions need to be taken with regard to control boards, relays, etc.
Reply:if you're not sure if it's wise to haul your welder through the car/truck wash throw a waterproof tarp over it.i.u.o.e. # 15queens, ny and sunny fla
Reply:Wax cycle is optional.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55Wax cycle is optional.
Reply:If you're talking a hand wand manual car wash, just use discretion when directing the pressure stream.If an automatic type it'll likely be no worse than if the welder were to be exposed to a downpour.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Jealous LOL My welding truck wont go thru a car washtrailblazer 302thunderbolt ac dc machine Hobart fluxcoreAHP tig 200x 2015
Reply:Originally Posted by akphillJealous LOL My welding truck wont go thru a car wash
Reply:Get the boot for the welder and fasten it to the welder and go for ittrailblazer 302thunderbolt ac dc machine Hobart fluxcoreAHP tig 200x 2015
Reply:Make sure it's not plugged in!  Lol just messing around disregard me.Forney C5 Arc WelderLincoln Idealarc 250-250 Ac/Dc Arc WelderMiller Bobcat 225g PlusLincoln PowerMig 200Forney O/A Rig
Reply:the sa-200 i own gets rained on any time it rains. works great.the tb 325 i operate gets rained on, plus washed, but never through a car wash, but is pressure washed, but never attempted to start shortly after pressure washing, but i have never exactly aimed the pressure washer at the 325 with intent. . . . . .boy you opened up a can o' worms. . . . .never thought about it, but for some reason, i say no car wash for welder, but i cant prove whybosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:How does the 305g compare to the vantage on welding arc everyday use?
Reply:Originally Posted by leeroy86How does the 305g compare to the vantage on welding arc everyday use?
GMT+8, 2026-1-2 15:40 , Processed in 0.092155 second(s), 18 queries .
