corten - genl info
发表于 2021-8-31 22:11:11 | 显示全部楼层 |阅读模式
http://www.ewf.be/media/documentosdo...ten_steels.pdf
Reply:I remember back in the early 80s when there was a big fascination with building things from Cor-Ten.   Can't recall hearing much about it in the last 15 to 20 years though.   I think CorTen might one of those supposed developments that while it sounded good in theory it didn't work out quite as well as expected.   In other words it wasn't quite the miracle material that it was originally advertised to be.   The Gardener Denver corporate offices in Dallas were built from it.  If my memory serves me correct it's one of the uglier buildings I've seen.
Reply:NRG Bridge.  Built in the 70s with Cor-Ten. Attached Images"Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Originally Posted by Marty Feldmanhttp://www.ewf.be/media/documentosdo...ten_steels.pdf
Reply:also called A588Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Most shipping containers are made with it"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Architects love the stuff,  It makes them go into cold sweats.      Im trying to warn this particular one that his visions are in excess of $50,000 and for a $550,000 home i dont think it needs that much planter street side.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:A 709 50 W to the bridge world today still used all the time. The new Witt Penn in NJ is all painted 50 W. HPS -70 W is higher yield and weathering too.Some dumb engineers want to waste money to galvanize or metalize it ,a total waste .
Reply:Originally Posted by ManoKaiNRG Bridge.  Built in the 70s with Cor-Ten.
GMT+8, 2026-1-2 15:40 , Processed in 0.107833 second(s), 18 queries .
