I went to a buddies shop today and noticed he was welding A large piece of aluminum tube to a Flat plate.... What caught my eye was He weaved the weld like he was welding a pipe joint...Even though the joint was well fit with no gaps....I wouldn't have welded that joint like that, you guys think It was over kill? Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Was he walking the cup? Maybe he did it for Uniformity.Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Originally Posted by B_CIt was over kill?
Reply:Hello B_C, depending upon the intent and use of this piece it may or not be detrimental. If he is attempting to maintain maximum strength in the as-welded condition the wide weaving is not for the better and especially if it is a heat-treated alloy such as 6061T-6. But even at that, if the part is a stand for an umbrella or something like that it probably isn't going to result in the end of his world. However, if it's purpose is one of importance the technique would not be the best choice as you said. Best regards, Allanaevald
Reply:Originally Posted by aevaldIf he is attempting to maintain maximum strength in the as-welded condition the wide weaving is not for the better and especially if it is a heat-treated alloy such as 6061T-6. But even at that, if the part is a stand for an umbrella or something like that it probably isn't going to result in the end of his world. However, if it's purpose is one of importance the technique would not be the best choice as you said. Best regards, Allan
Reply:Hello MikeGyver, I could agree with that if the plan was to possibly heat-treat after the welding was performed but I kinda doubt that is going to be the plan in this case. Just my $.02. Best regards, Allanaevald
Reply:Originally Posted by B_CI went to a buddies shop today and noticed he was welding A large piece of aluminum tube to a Flat plate.... What caught my eye was He weaved the weld like he was welding a pipe joint...Even though the joint was well fit with no gaps....I wouldn't have welded that joint like that, you guys think It was over kill?
Reply:Weaving. Sheet no, plate yes. Beer cans definitely.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Holy Crap, now I have a headache......Thanks Terry ..........lolLast edited by B_C; 01-08-2015 at 06:51 PM. Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by B_CHoly Crap, now I have a headache......Thanks Terry ..........lol
Reply:shovelon,I sure wish I'd have had your Dynasty700 (and your expertise on setting it and welding with it) when I did this heavy aluminum job. I had to do it with a Syncrowave 250. Even with some serious preheat from a rosebud about half way thru I smoked the 50 amp dryer plug on the machine right off the wall. It melted and failed in a pretty spectacular fashion. Had to stop and rob a plug off another machine in order to keep going and finish.
Reply:Originally Posted by HT2-4956shovelon,I sure wish I'd have had your Dynasty700 (and your expertise on setting it and welding with it) when I did this heavy aluminum job. I had to do it with a Syncrowave 250. Even with some serious preheat from a rosebud about half way thru I smoked the 50 amp dryer plug on the machine right off the wall. It melted and failed in a pretty spectacular fashion. Had to stop and rob a plug off another machine in order to keep going and finish. |
