Snow Roof Rake. Home made.
发表于 2021-8-31 22:11:08 | 显示全部楼层 |阅读模式
The average weight of a cubic foot of snow is 15 Lbs./Cu. Foot. So a 20' x 20' roof will have approx 6000lbs on it if there is a foot of snow. We have more than a foot of snow. I made a roof rake to remove the snow from the roof. Here it is. I remove the snow by standing on the flat bed of my truck on the front side of the house.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Purty cool.Lincoln AC-225 90 amp flux core
Reply:I would add axles on each side, small washers as wheels so the bottom isn't dragging on the roofing shingles.  Clearance of 1/8" should be good enough.Everlast PowerPro 256, Everlast W300 Cooler, Everlast Cart 250Millermatic 211, Spoolgun 100, Miller HD CartJackson W60 Truesight Digital Auto Darkening, Victor 315 Torch sitting on a Harper 830-86 cart
Reply:Originally Posted by Grandslam99I would add axles on each side, small washers as wheels so the bottom isn't dragging on the roofing shingles.  Clearance of 1/8" should be good enough.
Reply:Nice. This looks useful too.
Reply:I like that one ^^^^^^
Reply:Originally Posted by G-sonNice. This looks useful too.
Reply:Originally Posted by BrianCWhat keeps this from digging under the shingles?
GMT+8, 2026-1-2 15:38 , Processed in 0.099333 second(s), 18 queries .
