Take down bow handle
发表于 2021-8-31 22:11:07 | 显示全部楼层 |阅读模式
Not much welding here but a little and it is metal. I got stung on a deal on a hunting forum buying an ILF take down bow with 2 sets of limbs. The andle was delaminating and also had a crack in it. I decided to build my own out of aluminum. I took the old handle to the machine shop and had them cut it off at the right angles and drill and tap the appropriate holes. I took it to a friends shop and cut more off the block of aluminum. Every thing else was done with a 4 1/2" angle grinder and discs for aluminum. Shaping done, I finished up with sanding discs. I had my local powder coater put the finish on it, I put a leather grip on it and it is done. I haven't had a chance to shoot it yet.The only welding was two littlw pieces of bent 1/8" aluminum strap that had to be tigged to the handle at the ends of the limbs. I don't know that it needed them but all the handles I looked at on line had them so I put them on. They blended in well and maybe even made it look better. Attached Images
Reply:Here it is finished. Attached Images
Reply:Nice save Bob. Real nice.Sucks when ppl screw you, but what you got is better than what was on it in the first place!Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:You just lost a lot of redneck points!Very nice work! GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by GravelYou just lost a lot of redneck points!Very nice work!
GMT+8, 2026-1-2 15:40 , Processed in 0.097202 second(s), 18 queries .
