1956 Lincoln SA-200 Battery Door
发表于 2021-8-31 22:11:03 | 显示全部楼层 |阅读模式
Hi, I need a good used battery door, because mine is so corroded. If you have one for sale please let me know. Thanks!
Reply:I have a stainless steel cover plate that I made for a welder that I used to have. Its just a cover plate. Nothing fancy. I would have to check the distance between bolt centers because this was for a 60's welder. Not sure if they are the same. I'll upload some pics if you are interested.http://www.facebook.com/groups/sa200weldersCurrent machines:Hobart G600 Powered by 1967 Chrysler LH-318 (Project)Hobart GF-250(Traded)68 Redface81 Blackface
Reply:Thanks, I appreciate your post; I would really rather have an original used door in ok condition. I  may have to buy or make whatever I can get, though, so I will keep you in mind. You are right it is basically just a plate with a hole stamped for the crank.
GMT+8, 2026-1-2 15:41 , Processed in 0.104799 second(s), 18 queries .
