Coffing 2 Ton Electric Hoist
发表于 2021-8-31 22:11:02 | 显示全部楼层 |阅读模式
Coffing 2 Ton Electric HoistDescription:Model # EC4016.7This is a large frame motorized trolley model which comes standard with mechanical load brake, a motor brake, and an overload clutch. We purchased a long lift limiter ($363) and  100' of 1/2" heavy duty lift chain ($23ft.) for a job installing stair units in a high rise apartment complex. It also has the original 20' of 1/2" heavy duty lift chain w/ chain catch container (also has chain catch container for the 100’ chain).  Hoist has a Danfoss variable frequency drive 200-240v unit wired up which acts as a phase converter allowing hoist to be run off single phase power.  The load brake and overload clutches have been replaced with new ones.  Hoist is a single chain unit 2hp. motor with a load rating of 4000lbs. and lift speed (@ rated load) of 16ft. per minute, the push button control is 2 speed giving the option of a slower lift speed if needed.  Also included are the collectors for  overhead crane application, the standard lift limiter (for the 20’ chain), an extra set of wheels for the trolley and a heavy duty transfer dolly.  Very heavy unit @ 400 lbs for the hoist alone, the 2 chains w/ buckets together weigh approx. 320 lbs,  and the cart  approx. 80 lbs.Asking $2700 You can PM me with any questions or I can be reached at (214) 673-8910 (John) Like I said above this unit is very heavy so local pick up is preferred, but we will be happy to ship anywhere in continental USA as long as buyer pays all shipping & handling charges.  Thanks for taking the time to look! Attached Images
Reply:This hoist is sold
GMT+8, 2026-1-2 15:40 , Processed in 0.272865 second(s), 19 queries .
