lincoln 255 tig
发表于 2021-8-31 22:11:00 | 显示全部楼层 |阅读模式
I just bought a used  lincoln 255 Tig with a water cooled thumb control and down loaded the Lincoln  manual, There is very little usefull info there. I have a lincoln sp 200 Mig,.. Airco AC DC Hi Freq..and lincoln ac buz box, and an old lincoln gasoline powered trailer  that needs the engine rebuilt .I took a tig class a while back but the shop assistant set up the machine and we ran beads in Al, SS and steel,  I tig welded a little with the old  Airco but It was a hand crank adjustment and twist flow control.  torch.ok for heavier stuff.   I have a lot of questions about how to use the pulse,  ac balance and Hi freq . The work we do is repair our farm and construction equipment, heavy steel work, to patching light weight aluminum tubing for farm irrigation sprinkler piping.
Reply:You can read up on Pulse herehttp://newsgroups.derkeiler.com/Arch.../msg00024.htmlThis covers Balance and HFhttp://weldingweb.com/vbb/showthread.php?t=48176Last edited by Broccoli1; 01-07-2011 at 02:26 PM.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:thanks for the info, I looked at a Miller syncro tig,  with water cooler but it was scattered all over the guys garage, I had the cash and had the lift-gate truck ready to buy but told the guy to get it working first,.he never called me back.   I googled and downloaded the Miller book excelllent reference, I like my Lincoln stuff, but they could do a better job of providing information (copy Miller's example )
GMT+8, 2026-1-2 16:10 , Processed in 0.103205 second(s), 18 queries .
