SP - 100 Tips
发表于 2021-8-31 22:10:59 | 显示全部楼层 |阅读模式
I inherited my late Dads SP - 100 welder with less than 10 hrs. on it and would like to know where I might be able to pick up more tips for it. It has slip in tips and I tried my local welding shop ( Lincoln ) and he said they were not available. Would anyone have any suggestions?Any new old stock laying around?  This type of tip isn't threaded, and just slips into the gun.   I'm running .023 and could use some assistance.... Thanks...
Reply:Thats strange because any welding supply shop should be abel to order or retrofit with another  brand 023 and 025 are pretty much the same try some ruptabile welding suppliers they should have what your looking for good luck.Hobart mega arc 250 Airco dipstick160 air liquide cutting torches arc air gouger and so many more goodiesIf you cant dazzle them with brillants baffle them with bullsh$t
Reply:Slip in tip?  Hmmmm, never seen or heard of those before, but they may exist.  I have seen slip on nozzles and used them.  Are you sure its tips and not nozzles you are referring to?  If you can, post up a pic or pics of the tips you are referring to.  Or, if you have the manual, look up the part number and post the numbers.  Someone should be able to help.  If they are slip in/on tips, you may be able to change the gas diffuser to the style with threads where the tips install, that way you could use the standard threaded tip.  The "standard tip" should easily be found at any LWS, Home Depot, or Lowes.  Good luck and welcome to the forum!A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:You could try to adapt a tewco or lincoln diffuser to the old gun tube. then you can use any lincoln or tweco tip and nozzle you want. But you might be better off buying a new gun. A magnum 100 gun that will plug right in costs around $125.00  give or take a mark up.
Reply:The slip on SP-100 tips are no longer available. The best option is to buy the new style 100L gun that uses all 11 series standard tips. We have tried to retofit the old style gun several times but did not have any luck.
GMT+8, 2026-1-2 14:32 , Processed in 0.095339 second(s), 18 queries .
