Where To Attach Ground On SA 200 Shorthood?
发表于 2021-8-31 22:10:58 | 显示全部楼层 |阅读模式
I'm putting the starter back on the shorthood that I'm working on and was wondering where to attach the battery ground to.  I have installed a single wire alternator and it appears that the ground used to be attached at the point where the top alternator bracket is attached to the engine block now.  Does it need to be attached to the engine block or can it be attached to the frame somewhere?  (It has a F162 engine in it).StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:All mine are attached to the governor, with a braided ground strap from the same location down to the frame.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Here is a picture, this one doesn't have the braided ground strap on yet. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Thanks CEP....that hole is there on mine but no bolt and it was full of dirt.  I'll blow out the dirt and get a bolt and that oughta put me back on the road!StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:Originally Posted by CEPHere is a picture, this one doesn't have the braided ground strap on yet.
Reply:Originally Posted by jsm11Damn I want that welder!
Reply:You can only see the engine! How do you know you want it? OK is this better?  Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
GMT+8, 2026-1-2 14:32 , Processed in 0.092056 second(s), 18 queries .
