Walker Turner Drill Press Spindle
发表于 2021-8-31 22:10:55 | 显示全部楼层 |阅读模式
Spindle is bent on a small DP, causing some bad run out. Any idea where to get this part?Walker Turner "Driver Line"ser # 7DP 1039Thanks Attached ImagesBobcat 22512VSCST-280Millermatic 211Hypertherm Powemax 1000Victor O/A
Reply:If it is less than 36" long, I would turn it on my lathe.  I recommend finding someone with a lathe or donor machine for parts.
Reply:"If it is less than 36" long, I would turn it on my lathe"you must have a very special lathe to do those longitudnal groovesmiller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
Reply:Can you tell where it's bent? If you have a lathe you could start by mounting it between centers and see where it's out. It may take some time but you may be able to straighten it on the press.Are you sure it's not an issue with the chuck taper mount, it's not uncommon to bend at the transition between morris taper to jacobs taper as it's the thinnest spot. Of course I imagine you check the run-out with the chuck removed.
Reply:Walker Turner is Delta , dial indicate on lathe and straighten it out . Camshafts are strightenend between centers with a muffler chisel at Crane Cams.
Reply:I know I've seen a video on flame straightening... I was thinking it was one of Keith's but I can't find it. Here's one where he talks about checking the shaft. Maybe this will help. [ame]http://www.youtube.com/watch?v=bOT4cSTJyqw[/ame]
Reply:Originally Posted by forhireCan you tell where it's bent? If you have a lathe you could start by mounting it between centers and see where it's out. It may take some time but you may be able to straighten it on the press.Are you sure it's not an issue with the chuck taper mount, it's not uncommon to bend at the transition between morris taper to jacobs taper as it's the thinnest spot. Of course I imagine you check the run-out with the chuck removed.
Reply:Originally Posted by boatbuoy"If it is less than 36" long, I would turn it on my lathe"you must have a very special lathe to do those longitudnal grooves
Reply:If I can remember I will check as I scrapped something similar, but it did not have that tag, same brand though.
Reply:Never tried it but I would try mounting between centers in a lathe and put a dial indicator on it and find the center of the bend, both longitudinally and circumferentially.  I would then put the shaft in a press and apply pressure to the center of bend while indicating with a dial indicator to record how much deflection you apply.  You will have to keep trying to sneak up on getting it straight, you will have to apply deflection with the press slightly past the point of the shaft being straight to allow for springback, the dial indicator should let you know where you are at.  If that doesn't work getting a shaft made at a machine shop shouldn't be that expensive, however it may exceed the value of the old drill press.  Walker Turner drill presses were/are well regarded from what I have read on the internet.Please post back and let us know what you ended up doing."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Thanks for all the replies, I sent an email to Plaza Machinery, per Dunemetal's post, and I have contacted 2 other people I found online that deal in machine parts. I am waiting for a response.I don't have a lathe or mill...lolThis is a great drill press, so I don't want to abandon it yet, its rock solid and much better quality than some of the newer "plastic" drills out there. What do you guys think it would cost to have a machine shop make me another one?Thanks again!-RGBobcat 22512VSCST-280Millermatic 211Hypertherm Powemax 1000Victor O/A
Reply:I just got a reply from Walker Turner Serviced Machinery, the cost of a replacement spindle is $93+15 to ship. Ill wait to see what some other qoutes come in before I make a decision.BTW, interesting video on shaft straightning. I would try it if I had a lathe.-RGBobcat 22512VSCST-280Millermatic 211Hypertherm Powemax 1000Victor O/A
Reply:Originally Posted by RGalyonI just got a reply from Walker Turner Serviced Machinery, the cost of a replacement spindle is $93+15 to ship. Ill wait to see what some other qoutes come in before I make a decision.BTW, interesting video on shaft straightning. I would try it if I had a lathe.-RG
Reply:Originally Posted by RGalyonI just got a reply from Walker Turner Serviced Machinery, the cost of a replacement spindle is $93+15 to ship.-RG
Reply:Exactly. This machine is build like a tank, and the $108 bucks is well worth it. Plaza Machine got back to me this morning asking some specifics, so im waiting for the rfq from him.-RGBobcat 22512VSCST-280Millermatic 211Hypertherm Powemax 1000Victor O/A
Reply:That spindle is pretty easy to make, but I'ld bet you'ld pay a lot more than $93 to have one made. I have the same drill press. Good old machine.
Reply:I received the spindal in the mail today, installed it and the drill runs like a swiss watch. I would recommend Walker Turner Serviced Machinery, as the communication was good and shipping prompt.Bobcat 22512VSCST-280Millermatic 211Hypertherm Powemax 1000Victor O/A
Reply:Great news.  Thanks for letting us know.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
GMT+8, 2026-1-2 14:49 , Processed in 0.101683 second(s), 18 queries .
